After I export my data to a shapefile, I have a range of addresses for which I need to replace their suffixes from Dr to Ave. I'm using a process I developed in Model Builder to perform the export. Is there a way to script the edit, and integrate it into my process model? Thanks.
Thanks for your help. I was able to build the process in Model Builder and integrate it with my data export model.
import arcpy import os import string import re arcpy.env.workspace = r'C:\Workspace\PARCELIDCLEANUP.gdb' fcs = arcpy.ListFeatureClasses() # Create list of fields for keeping s = ['PARCELNO'] for fc in fcs: print "** Now working on "+fc fields = arcpy.ListFields(fc) for field in fields: if field.baseName in s: rows = arcpy.UpdateCursor(fc) for row in rows: targetRow = row.PARCELNO row.PARCELNO = targetRow.replace(' ','') row.PARCELNO = targetRow.replace('-','') rows.updateRow(row) del row del rows print " Parcelno cleaned" if not field.baseName in s: None print "PARCELNO is edited"
