Are you using the Map's MapGesture Hold? Moving a MapPoint is supported by EditVertices. You can either move the point using your mouse or using touch. They should behave the same way - for mouse: you press on MouseLeftButtonDown, move the mouse and release to let go; for touch: you touch down on graphic, move your touch to drag the item and touch up to let go.Are you saying the graphic you choose to move does not move, instead another graphic is moved? Or are you simply looking for an event to know which graphic was moved?
