I had this error when clicking on a gdb, then changing the XML Workspace Document to a nonexistent directory:
xml export database error: exception from hresult: 0x8004216A
Failed to export <gdbName>.gdb
The directory must exist prior to running the "Export GDB to XML Workspace (Schema Only) tool:
This successfully exports and opens the xml in preparation for creating the .htm web file:
How To: Create a data dictionary of a file geodatabase using the X-Ray for ArcCatalog add-in
Thanks a lot Steve. I didn´t have Excel installed. Problem solved!
I'm not sure what the issue is offhand. Are you able to open another
simpler xml workspace document?
Also I can't tell from the info which version of the software you are
running, and if you have Excel installed. To me it looks like an issue with
the Excel install, which might also be complicated by non-English version
of Windows, I'm not sure.
There's a new version at
http://www.arcgis.com/home/item.html?id=9ea218ff575f4a5195e01a2cae03a0ae
that includes enhanced validation. I don't think that would address your
specific issue, but you might try that along with making sure that you can
do a basic export/import from a Geodatabase.
Hello, I am experiencing problems when I try to open the UPDM.xml file for gas utilities with x-ray. The steps I followed are the following:
1-Select the xml file in the contents pane.
2-press the open xml button.
The following image shows the error which says it is not finding the file. I can´t really understand what is going on since the steps are quite straightforward. Any ideas?
Thanks in advance.
I tried this too. I even closed the catalog tree so that I only had the contents window available. I am able to export out and import back in other databases. I think I am using the tool correctly and the error is probably something I introduced on the spreadsheets and the xml but the error message is so cryptic that it does not help me troubleshoot the problem.
X-Ray for ArcCatalog is very fussy. You have to click things in the right place and at the right time and follow the instructions exactly.
I wrote a blog entry mostly for my own reference to help me when I needed to do it again. You need to follow these instructions. When it tells you to select things in the contents window that's where you need to select it. Don't forget the step that directs you to save the xml schema after you set the spatial reference.
Hello all,
I am having a very similar error to the one shown on this thread. The error says: "Xml Import Error: Type Mismatch. (Exception from HRESULT:0x002005). DISP_E_TYPEMISMATCH))
This happens when I try to import the xml schema. I have validated it until it has no errors. I have also tried the workaround about the about the spatial reference described on this thread. I have set it via the Options menu and by selecting a feature dataset on the database.
I have also looked for empty worksheets on the spreadsheets but no success there either. I am using Arc 10.2.03348 and version 10.2.2 of the add-in. Any ideas?
Ovidio
