# --------------------------------------------------------------------------- # gisbuild_layer.py # Created on: 2011-09-29 11:35:46.00000 # (generated by ArcGIS/ModelBuilder) # Author: Anastasia Aourik # Description: # Regenerate featureclass WG_POMDJOBS from source table with xy values # --------------------------------------------------------------------------- # Import arcpy module import arcpy, os, datetime arcpy.env.overwriteOutput = True # Local variables: WCSS_SOURCE = "Database Connections\\OLE DB ConnectionMYDRS0.odc\\WCSS.POMD_JOBREC_MV" WCSS_Layer = "WCSS_Layer" SIIGIS_WG_LAYER = "Database Connections\\Connection to sql04.sde\\siiview.SIIGIS.WELLSGENERAL\\siiview.SIIGIS.WG_POMDJOBS" now = datetime.datetime.now() print "GisBuild of PATHFINDER JOBS" print "Started: " + str(now) try: if arcpy.Exists(WCSS_SOURCE): # Process: Make XY Event Layer print "Source Table Exists" arcpy.MakeXYEventLayer_management(WCSS_SOURCE, "LONGITUDE_NBR", "LATITUDE_NBR", WCSS_Layer, "GEOGCS['GCS_WGS_1984',DATUM['D_WGS_1984',SPHEROID['WGS_1984',6378137.0,298.257223563]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]];-400 -400 1000000000;-100000 10000;-100000 10000;8.98315284119522E-09;0.001;0.001;IsHighPrecision", "") print "Make XY Layer Succeeded" if arcpy.Exists(WCSS_Layer): print "Proceed to Copy Features" # Process: Copy Features print "Begin Copy Features Management" arcpy.CopyFeatures_management(WCSS_Layer, SIIGIS_WG_LAYER, "", "0", "0", "0") print "All Features Copied\n" now = datetime.datetime.now() print "Ended: " + str(now) + "\n" except: arcpy.AddError("Python Messages: " + arcpy.GetMessages())
