I am told to update a shapefile (add new records to it) before I can use it to produce a map. To update the shapefile, I opened its attribute table and then used "Start Editing" and "Add new features" option to enter the new records.As I updated the shapefile this way (by editing the table and adding the new records), I think that the XY coordinates were not lost for the old records. However, I am wondering if I have to geocode again the shapefile in order for the new records to have a positional location attached to them and then use the exported shapefile (obtained after geocoding) to make my map? Thanks.
I am not certain what you did but did you open the dbf in something like excel and add the records.You cannot do that with a shapefile. you will lose everything or if you don't lose it you can scramble the data records. The dbf rows are tied to a specific graphical feature. if you make changes to the dbf you alter which record is tied to which graphic.if you need to edit a shapefile you do it in an ArcGIS session.
I edited the shapefile to add the new records in an ArcGIS session.First I thought about exporting the shapefile to Excel and then add the new records there, but I didn't do it. Because I thought the old records would lose their XY coordinates.So, after I added the new records in an ArcGis session, do I have to geocode the shapefile(table) again and use the new shapefile obtained from geocoding to make my map?.
Is this a point shapefile? If so, maybe you can do a field calc on the fields holding the x and y coordinates using getx and gety on the shape field which should be available through the field calculator.
If you added them in an ArcGIS session why would you need to geocode them. They should already be placed where you want them. Typically geocoding is performed on a set of data that is not a shape file or feature class.
You should geocode the new data separately then merge the two files together
The new data (the new records I'm going to add to the shapefile) I was given is in Excel. These records are new facilities that will be added to the old facilites that are in the shapefile. In the attributes list of these new facilites, there is no latitude and longitude, but attributes such as name, address, zip code, year the facility was built, etc...As you said I have to geocode the new data and merge it, can you tell me how I can import this Excel file into ArcGIS and then geocode it?I think I have to create shapefile with this new data before I geocode it, right? If so how can I create a shapefile with this new data in Excel?I am not sure, but can I create a shapefile with this new data by importing it into Mcrosoft Access to create a table with it and then import this table into ArcGIS?Thanks.
