Richard,I would consider abandoning your approach of using the IDataStatistics interface as ESRI introduced a bug with the 10.1 SP1 release that is some sort of memory leak and will cause your application to fail. It is discussed in this thread.I had terrible problems with my application failing until I stopped using it. Hopefully they will fix it in 10.2Richards idea of calling the summary tool is probably the easiest way of doing things.Duncan
Summary Statistics and then look for values with a count of 2 or higher. Relate or join to get the selection on the original features. Then do whatever you need to do to deal with them. This method is so fast and easy, I have not found a reason to program an alternative.
Try 'Defining the Layer selected by the end user Dim layer As String = ComboBoxLayerName.SelectedItem 'Converting the layer into a feature class Dim fclass As IFeatureClass = flayer(layer).FeatureClass 'defining the field to be checked Dim fieldToCheck As IField = Nothing Dim fields As IFields = fclass.Fields Dim t As Integer = 0 Do While (t < fields.FieldCount) If fields.Field(t).Name = ComboBoxFieldName.SelectedItem Then fieldToCheck = fields.Field(t) Exit Do End If t = t + 1 Loop 'define the cursor to store data Dim pCursor As ICursor 'define datastat to query unique values Dim pDataStats As New ESRI.ArcGIS.Geodatabase.DataStatistics 'define data collection Dim pEnum As System.Collections.IEnumerator Dim duplicateNumber As Integer Dim duplicateValue As Integer = pDataStats.UniqueValueCount '(DuplicateValue here returns the total records in the field) ListViewResults.Items.Clear() pCursor = fclass.Search(Nothing, False) pDataStats.Field = fieldToCheck.Name pDataStats.Cursor = pCursor pEnum = pDataStats.UniqueValues '(pEnum get Unique Values in the field) pEnum.Reset() Dim pListItem As New ListViewItem Do While pEnum.MoveNext duplicateNumber = pDataStats.UniqueValueCount ListViewResults.Items.Add(pEnum.Current) ListViewResults.Items(0).SubItems.Add(pDataStats.UniqueValueCount.ToString) '(return the total records number but not the number for each repeated records) Loop Catch ex As Exception MessageBox.Show(ex.Message) End Try
Hi,I want to check if a specified field has duplicate records. is there to achieve this? I am using VB.NET.Please any help will be helpful.
