on(featureLayerInstance, "click", function (evt) { var graphic = evt.graphic; var countryName = evt.graphic.attributes.CNTRY_NAME; console.log(" got countryName" + countryName); var alertDetailUrl = getAlertDetailsUrl(countryName); console.log(" alertDetailUrl " + alertDetailUrl); dojo.xhrGet({ url: alertDetailUrl, handleAs: 'json', load: function(data){ console.log("data "); var popUpData = getPopUpContent(data); map.infoWindow.setTitle(countryName); map.infoWindow.setContent(popUpData); map.infoWindow.show(evt.mapPoint); console.log(" complete "); }, error: dojo.hitch(this, "failure") }); });
on(featureLayerInstance, "click", function (evt) { var graphic = evt.graphic; var countryName = evt.graphic.attributes.CNTRY_NAME; var template=new InfoTemplate(); console.log(" got countryName" + countryName); var alertDetailUrl = getAlertDetailsUrl(countryName); console.log(" alertDetailUrl " + alertDetailUrl); dojo.xhrGet({ url: alertDetailUrl, handleAs: 'json', load: function(data){ console.log("data "); var popUpData = getPopUpContent(data); template.setTitle(countryName); template.setContent(popUpData); graphic.setInfoTemplate(template); //You don't needto add the graphic to the map unless you want to give it a new selection symbol. //map.graphics.add(graphic); //graphic.show(); console.log(" complete "); }, error: dojo.hitch(this, "failure") }); });
function getData(evt){ try { require(["esri/InfoTemplate"], function(InfoTemplate){ var graphic = evt.graphic; var countryName = evt.graphic.attributes.CNTRY_NAME; var template=new InfoTemplate(); console.log(" got countryName" + countryName); var alertDetailUrl = getAlertDetailsUrl(countryName); console.log(" alertDetailUrl " + alertDetailUrl); dojo.xhrGet({ url: alertDetailUrl, handleAs: 'json', load: function(data){ console.log("data "); var popUpData = getPopUpContent(data); template.setTitle(countryName); template.setContent(popUpData); graphic.setInfoTemplate(template); map.graphics.add(graphic); graphic.show(); console.log(" complete "); }, error: dojo.hitch(this, "failure") }); }); } catch (e) { console.log("error occured " + e); } }
// Function to format info window content based on feature attributes function featureContent(feature) { var type = feature.attributes["TYPE"]; var notes = feature.attributes["NOTES"]; var baseContent = "<strong>Type:</strong> " + type; if (notes) { baseContent += "<br/><strong>Info:</strong> <span class='data'>" + notes + "</span>"; } return baseContent; } var idTask = new IdentifyTask(mapUrl); var idParams = new IdentifyParams(); idParams.returnGeometry = true; idParams.layerIds = [56, 59]; idParams.layerOption = IdentifyParams.LAYER_OPTION_TOP; idParams.tolerance = 5; function infoTask(evt) { idParams.geometry = evt.mapPoint; idParams.width = map.width; idParams.height = map.height; idParams.mapExtent = map.extent; idTask.execute(idParams, function (idResults) { if (idResults[0]) { array.forEach(idResults, function (result) { var selFeature = result.feature; map.infoWindow.setTitle(result.layerName); var content = featureContent(selFeature); map.infoWindow.setContent(content); map.infoWindow.show(evt.mapPoint); }); } }, null); } on(map, "click", infoTask);
