Hey DanI am currently working on a model similar to what your working on. I too am working with a set of pipes within a regulator area and doing analysis on leak repairs. The main thing that I would do is instead using Spatial Join I would use Identity. That way your taking away an extra step from your model because the identity does an intersect and then names it by the intersecting features, and then just run a Summary Stats on the Length for the pipes. Then for your Leaks you can run an identity again and either get a frequency or select by attributes of regulator area name and then get count. Also one thing you can look for if your not using arc info and have a lot of data is the Split Layer by Attributes Tool, its somewhere around on these forums. Its essentially the Split tool used in ArcInfo. Once you download that tool and add it use the output from your identity to split your features. This tool is cool cause you can make your model faster and not have to select by location or attribute, just make sure you dont have them as layers in arcmap you the add data button and use it that way. Hopefully that helpedBcraddick
