I want to merge random polygons placed on a graphics layer make a single polygon with only one boundary. Also how to unmerge them.
I think this function works for only intersected boundaries: i used the solution below, and it is working fine.
merge.addEventListener('click',function(){ var updatedGeometry=new Array(); graphicsLayer.graphics.map(function(gra){ updatedGeometry.push(new Polygon((gra.geometry))); }); var joinedPolygons = geometryEngine.union(updatedGeometry); graphicsLayer.removeAll(); joinedPolygons.rings.forEach(function(ring) { resultpolygon={type:"polygon",rings:[ring]}; var resultgraphic =new Graphic({ geometry: resultpolygon, symbol: resultsymbol }); graphicsLayer.add(resultgraphic); // console.log(ring); }); });
Merge/Union: https://developers.arcgis.com/javascript/latest/api-reference/esri-geometry-geometryEngine.html#union
To un-merge you loop though the Polygons rings and copy those ring arrays to another Polygon class.
hi robert,
long time to hear from your side... how are you, well thanks for the reply, i already get the union link, but couldn't find any example, if u have any link then pls send..
like i have found this
Merge Polygons in JavaScript API 4.14
Do, i need to to loop through all the polygons of a layer, to get its graphics geomtrry
Correct. The Union works with the actual geometry not the layer.
jQuery('#main').on('click','.merge_boundary',function(){ var updatedGeometry=new Array(); graphicsLayer.graphics.map(function(gra){ updatedGeometry.push(webMercatorUtils.webMercatorToGeographic(gra.geometry)); }); var joinedPolygons = geometryEngine.union(updatedGeometry);//it returned all polygons as it is, do not merge to make it one console.log(joinedPolygons.rings); addGraphics(joinedPolygons.rings); });
