There's shp with a lot of points. GPS puts the point and I need to open the attributes of the closest point in edit mode. how to implement it?thanksChingiz
Dim objRS, Layer, Bookmark, X, Y, MaxDistance Set Layer = Map.Layers("LayerName to search for") MaxDistance = "1000" ' Distance is in map units ' Select the nearest point X = GPS.X Y = GPS.Y Set objRS = Layer.Records Bookmark = objRS.FindNearestXY(X, Y, MaxDistance) Call Map.Select(Layer, Bookmark) ' Show the attributes of the selected point If Bookmark <> 0 Then If Layer.CanEdit Then Layer.Editable = True Call Application.ExecuteCommand("featureproperties") End If Else Call MsgBox("Nothing Found") End If
