So essentially there is no way to do an identify with hyperlink in the Flex SV 2.0 when using Server 9.3you have to use 10 and specify a feature layer... The only way I get hyperlinks to work with 9.3 is by using the query widget which for some reason highlights my entire layer... in hot pink red... (See attached) How can I get the mother of all highlights to go away. BTW I can get identify to work in this state when I use the InfoPopupWidget.swf instead of the SimpleInfoWinWidget.swf in my config file...
It helps to let the forum know which version of ArcGIS Server you are using as well, due to the fact that AGS 10 has the "FeatureServer" capability, while 9.3.1 does not have this option. For Flex 2.0, it really is best to have AGS 10 in my experience, due to the samples ESRI gives use the FeatureServer capability for the InfoPopup samples.Try switching your type from feature to dynamic if you are not using AGS 10, and it should show up then.
