function onResult(results:Array, clickGraphic:Graphic = null):void { if (results && results.length > 0) { var result:IdentifyResult = results[0]; var resultGraphic:Graphic = result.feature; var mapPoint:MapPoint = MapPoint(clickGraphic.geometry); var point:Point = mainMap.toScreen(mapPoint); mainMap.infoWindow.hide(); switch (resultGraphic.geometry.type) { case Geometry.MAPPOINT: { mainMap.infoWindow.content = createVideoWindow(resultGraphic, xmlProjectParameters, divephotourl, divevideourl, site_id, videoname, photocount); mainMap.infoWindow.label = "Site ID: " + resultGraphic.attributes[site_id]; resultGraphic.symbol = new SimpleMarkerSymbol("x",12,0xFF0080); break; } } layerGraphics.graphicProvider = resultGraphic; mainMap.infoWindow.show(mainMap.toMap(point)); } } public static function createVideoWindow(graphic:Graphic, xmlProjectParameters:XMLList, photoURL:String, videoURL:String, siteID:String, videoName:String, photoCount:String):VideoPopup { var popVideo:VideoPopup = new VideoPopup(); popVideo.TitleText = graphic.attributes[siteID]; popVideo.VideoName = graphic.attributes[videoName]; popVideo.attributeText = returnAttributes(graphic, xmlProjectParameters, 0); //a function to get all the attributes popVideo.imageCount = graphic.attributes[photoCount]; popVideo.photoURL = photoURL; popVideo.videoURL = videoURL; return popVideo; }
<esri:Map id="myMap" load="loadHandler()"> <esri:infoWindowContent> <s:VideoPlayer width="480" height="360"> <s:DynamicStreamingVideoSource host="rtmp://111.111.11.111/live/" streamType="live"> <s:DynamicStreamingVideoItem streamName="yourStreamName" /> </s:DynamicStreamingVideoSource> </s:VideoPlayer> </esri:infoWindowContent> </esri:Map>
