Is updating a Tile Package hosted on AGOL with Python even possible? There used to be https://cloudygis.maps.arcgis.com/home/item.html?id=d829e15ca7d840f29b1a1d8d2e8b7ac7 which no longer works due to SSL settings, which even when tell urllib to ignore the warnings, it still doesn't work. Surely someone has solved this?
Trying TileSharingDraft—Sharing module | Documentation , and I see
Specifies whether an existing service with the same name will be overwritten.
in the documentation, but sharing_draft.overwriteExistingService = "True" (and I tried "true") results in
Service name 'GRSM_STORM_TOTAL_PRECIP_TILES' already exists for 'orgid'Failed to execute (UploadServiceDefinition).
Is the documentation wrong, or is there a bug and you can't use TileSharingDraft—Sharing module | Documentation to overwrite an existing tile service despite the documentation suggesting otherwise?
booleans shouldn't be enclosed in quotes ... True ... by itself. If it requires a string, it should be stated as such and would definitely be an error in the documentation. ( True != "true" != "True" )
Helpful, changed it, BUT, same error:
env—ArcPy classes | Documentation
if it is a script and deleting that type of object is supported
