I had the same problem. But the "simple" solution is to use "Save as" and not "Export". In the "save project document" dialog select "On a Web Server".
We did not get a chance to install/test under Beta 1, but are now working on getting Beta 2 installed. Unfortunately, most of the support information for Mobile still seems to refer to Beta 1. I did not see an option for a "Project Server" installation under ArcGIS Server .NET when we installed it (Beta 2), nor did I see a separate installation package, either on the ArcGIS Server ISO or the ArcGIS Mobile ISO. Is there something that we missed when we did the install?We've been able to create a mobile service, access it through the Mobile Project Center, and save a mobile project locally through MPC. However, our installation of MPC does not seem to include any options for specifying or managing a mobile project server. When we try to export the project (AMP file), only local options are enabled. Are we still missing a component of the install?I apologize if we're overlooking something basic - we had 9.3 running pretty easily, but can't seem to get 9.4 up and running.
Hopefully yes. We are working on new setups for ArcGIS Server .NET and inside of the new setup we will include the "Project Server". I cannot confirm for sure that the new setup will be in beta 2 but we are working towards making that happen.For beta 1 you will need to run the separate project server setup.
