Has anyone used the "Drinking Water Advisory" solution? If I create a Boil Alert on the Drinking Water Alert Web map by drawing a polygon to represent a boil order, save it, and then try to share it, the alert polygon disappears. If I leave that same web map and come back to it, the polygon also disappears, even if I save it. If I go to the Drinking Water Advisory Management map, it will show the polygon that I drew on the Alert map, but shows it as a past alert and not current. Anyone else have this problem, or is there something I'm missing?
Also, is there a way to embed or share the map that only shows the polygon and nothing else like water mains and valves. I need those two layers to determine where to draw the polygon, but I don't necessarily need to show the public our infrastructure.
Thank you!
Travis
