I may be missing something in the documentation, but I cannot figure out how to redirect requests over port 80 to automatically redirect to my https-configured web adaptor. I can currently get to https://domain/webadaptor/rest, but do not get redirected to that url when going to http://domain/webadaptor/rest. I've tried setting up a rule in IIS with URL Rewrite, but no dice. Any advice on how to set this up? I am probably missing something obvious here because it seems like almost any organization would want this to happen. Users can't be expected to type in http:// everytime.
Thank in advance
Mike
This has nothing to do with the web adaptor but everything with IIS. Also, you can still use Web adaptors when using NLB appliances.
Either you need an external appliance to redirect (e.g. F5, KEMP, Citrix etc)
or you install and configure URL Rewrite.
I can only suspect that the url rewrite rule applied to the IIS application (in this case, the Web adaptor) was incorrectly configured OR my other suspiciton is that you are unaware that installing the web adaptor,choosing 443 will change some IIS settings which the URL redirect may not work under.
Lets make sure your redirect (using URL Rewrite) is setup first..
using IIS 8.5
type in the http link to the web adaptor.. get a 403.
go to IIS
you will have already installed the urlrewrite either on its own or using the web platform installer.
e.g.
Here you can see 3.21 (JSAPI) and the arcgis web adaptor
You can create the new inbound rule to the site so that all child applications will get the redirect.
Add rules
Add a blank inbound rule
Name it, Redirects to HTTPS
pattern: (.*)
Add a condition
Condition input is {HTTPS}
Pattern: ^OFF$
Press OK
Go to ACTION pulldown panel
Action Type: Redirect
Redirect URL: https://{HTTP_HOST}/{R:1}
Redirect Type: See Other (303)
Click on APPLY
Verify the changes were successful
IIS will now look like so:
Lets refresh our default page.
yes... redirects.
try a JSAPI under 3.21
yes.. redirects
Try the web adaptor...
In your case, i 'suspect' that it will not work...
go to the SSL settings for the web adaptor:
If Require SSL is checked... uncheck it.
Make sure to apply and verify successful
*** what i have found is that when installing the web adaptor, choosing port 443 auto checks a setting interfering with the URL Redirect.
Now try your web adaptor link... (not even http just machine name...(or http)
and you should now get redirected to HTTPS
Of course, next step is to get a valid cert....
Have you taken a look at the Disable http access to ArcGIS Server section of the doc?
Yes. That was the first thing I did in my process. I've configured ArcGIS Server many times before, but I typically use an AWS load balancer instead of the web adaptor. I can successfully connect to https://<my domain>/arcgis/rest, but when going to http://<my domain>/arcgis/rest, I see the error below:
Maybe I have something configured incorrectly in IIS? I have bindings for 80 and 443, with 443 using an SSL cert for <my domain>.
I just went through the instructions in the link below and it seems to work:
Redirect from HTTP to HTTPS using the IIS URL Rewrite module – Damian Wiese
Have you taken a look at that?
My guess is that would not solve knowing that installing the Web adaptor changes IIS settings, specifically the REQUIRE SSL setting which would interfere with URL Rewrite (redirect).
I've provided an extraction out of my documentation step by step which should get Michael up and running.
Thank you for the detailed instructions, Michael. I actually already had my URL Rewrite rule set this way and did not have SSL settings checked. The redirect is working on the server now, but not from the outside. I will have to check with the IT folks to see if they are blocking 80, 443, 6080, or 6443 outside of the network.
Hi Michael,
Its good to have all the steps to help with troubleshooting.
Regarding the outside traffic. You would hit the web adaptor, which is port 443.
Port 6080 and 6443 is only between ArcGIS Server (AGS) and the machine with the web adaptor. you are saying this works on the server.
Is it possible that there are additional hardware, traffic manipulation occuring with the incoming traffic?
It sounds like you are one step closer.
Resolved. The IT folks were blocking something at the firewall. It's purring like a kitten now! Thanks for your help
The whole purpose of the web adaptor is so that ports may be omitted on URLs when browsed from a client browser. Using the port is actually by-passing the web adaptor, and being unable to reach the server using the port from a client browser would likely indicate that the network policies are presenting it.
Given the pic above, your server can only be reached via HTTPS, i.e., port 6443. If you want to change that, you'd have to change the security settings via https://<server>:6443/arcgis/admin on the server:
Otherwise, to get to the server's service directory (if not disabled), you'd have to browse to https://<server>/arcgis/rest/services WITHOUT a :6443 port designation from a client browser.
I am not using any ports in my url. This discussion was about the automatic behind-the-scenes http-to-https redirect. We use either http://domain/webadaptor/rest or https://domain/webadaptor/rest. ArcGIS Server is set to HTTPS only.
Hi Carlos,
Though this discussion had nothing to do with direct access to ArcGIS Server (ports - which are 6443/6080 by default - if your savvy can be changed to any port you want), I'd like to clarify some information.
Carlos Colón-Maldonado wrote:The whole purpose of the web adaptor is so that ports may be omitted on URLs when browsed from a client
wrong.
The web adaptor allows integrating a web server with a GIS Site (remember, a site can have multiple GIS Machines / nodes). A web adaptor forwards calls to your ArcGIS Server nodes and will check your site to see removed or added machines.
A web adaptor also allows exposing the GIS Servers through the standard website port (80/443). Since this is a web standard, these ports are not visible from a clients perspective, but they are still there.
The web adaptor also provides the ability to restrict Desktop ArcGIS Server users from Admin and Publishing access.
And very important, the web adaptor allows leveraging enterprise security from a web-tier level.
using IWA (integrated windows authentication) MUST use a web adaptor on a web server level, the web adaptor WA (windows authentication) - e.g. NTLM or Kerberos PASSES these credentials to ArcGIS Server for all secure services. ArcGIS Server identity store would be tied to Active Directory (for example). This means, only traffic through the web adaptor can only see locked secure services with valid credentials... even if the user had access directly to arcgis server using port (e.g. 6443 - going around the web adaptor)- they would get an unauthorized response because ArcGIS Server is expecting valid credentials from traffic through the web adaptor.
