Turns out it was a bad video driver. Client update their driver and the map opened.
I recently sent a client their data and ArcReader 10.1 doc. They are using Windows 8 and when opening the document ArcReader crashes. No error message, just disappears. The client is able to start ArcReader without crashing, so I've ruled out the install being bad, but the same behavior occurs when opening the doc from the File menu. I have since tested the document and data using a Windows 8 machine we have in-house and I can open the document without problems.We have tried the following with no luck:Moved the data and document from a network location to local machine - still crashesDisabled anti-virus - still crashesUpgraded all underlying personal and file geodatabases to 10.1 - still crashesOther info:The client had been successfully using ArcReader 9.3 on Windows 8 prior to upgrading to 10.1The map contains only data from personal and file geodatabases, one shapefile, and a Mr SID orthoAny insight as to the possible cause/solution or where I can look to get more details on why this is happening?
