I am trying to fix my attribute records in Arcmap.
Is there a way to do a bulk fixing, to find all my St and change it to Street?
Here's a simple Python field calculator example:
!fieldnamehere!.replace(' ST', ' STREET')
Longer example for addressing multiple changes. Use your fieldname instead of FacilityAddress.
def StreetSuffix(FacilityAddress): list = FacilityAddress.split() for item in range(len(list)): if list[item] == 'STREET': list[item] = list[item].replace("STREET", "ST") if list[item] == 'STREET,': list[item] = list[item].replace("STREET,", "ST") if list[item] == 'STR.': list[item] = list[item].replace("STR.", "ST") if list[item] == 'STR,': list[item] = list[item].replace("STR,", "ST") if list[item] == 'ST.': list[item] = list[item].replace("ST.", "ST") if list[item] == 'ST,': list[item] = list[item].replace("ST,", "ST") if list[item] == 'WAY': list[item] = list[item].replace("WAY", "WY") if list[item] == 'WAY,': list[item] = list[item].replace("WAY,", "WY") if list[item] == 'WY.': list[item] = list[item].replace("WY.", "WY") if list[item] == 'WY,': list[item] = list[item].replace("WY,", "WY") return " ".join(list)
Credit to Darren Wiens and several others knowledgeable in Python for coming up with this, which I gratefully stole borrowed.
Chris Donohue, GISP
There is Find and Replace in Table options.
Yes, this can be done in Python. The Python code can be placed in the field calculator, or a pure Python run can be done.
Or select thuroghfare trailingtype = 'ST' and then calc thuroghfare trainingtype = "STREET"
Thanks Darren!
Got it fixed. Saved me tons of hours.
Now that I see this again, a more compact alternative may be (only lightly tested):
def StreetSuffix(FacilityAddress): replace_dict = { 'ST':['STREET','STREET,','STR.','STR,','ST.','ST,'], 'WY':['WAY','WAY,','WY.','WY,'] } list = FacilityAddress.split() for item in range(len(list)): for key, value in replace_dict.iteritems(): if list[item] in value: list[item] = key return " ".join(list)
@ChrisDonohue__GISP
I just wanted to thank you for posting this field calculator expression. I needed to update addresses in a single field to change all abbreviations to fully spelled out words. I used this expression in ArcGIS Pro, created a list of changes I needed, and updated over 16000 records with little issues. It worked great!! A huge time saver, and I learned some good skills from it.
Thank you!
Jon
