I have found multiple threads about populating a dgrid from results of a query task, but I still can't figure out what is wrong with the way I have my dGrid and Memory created. I have multiple queries getting executed, and each of the query results will be put in a separate Title Pane within a Floating Pane. The title panes are getting created and I see that my Memory is populated, but I must not have this formatted correctly, because when I use it as the store for my dGrid, I get an empty grid. The loop that reads the attribute names to create the columns look right.function queryGeometryResultsHandler_toGrid(results, idx) { //format the data for the data grid var dataList = {}; dataList.data = arrayUtils.map(results.features, function(feature){ return feature.attributes; }); var currentMemory = new Memory({data:dataList.data, idProperty:'OBJECTID'}); var gridcolumns = []; for (attName in dataList.data[0]) { if (attName != "Shape" && attName !== "Shape.area" && attName !== "Shape.len") { var objects = {}; objects.label = attName; objects.field = attName; gridcolumns.push(objects); } } //create a titlePane in the floatingPane for each visible layer var currentLayerId = qTaskNameList[idx];//a list of layers created in query task functions var paneTitle = (currentLayerId.split('_').join(' '))+" ("+results.features.length+")";//formats string to look nice tp = new TitlePane({ id: 'gridPane_'+currentLayerId, title: paneTitle, splitter:true, class:'reportTitlePane'}); registry.byId("reportContainer").addChild(tp); tp.startup(); // Create Grid using structure and data defined above grid = new Grid({id:currentLayerId+'_grid', autoHeight:true, columns:gridcolumns, store:currentMemory} ); //dgrid grid.startup(); if (results.features.length > 0) { tp.set("content", grid); }else { tp.set("content", "No features found"); } }
I had this working in non-AMD style, but there I was using ItemFileReadStore and Dojox.Grid.DataGrid, so I know my theory is basically sound, just not the syntax.Here's a link. You have to turn on some layer other than legislative districts, like schools, and then enter a district number to initiate the query. https://ogitest.oa.mo.gov/LEGIS/LegislativeAnalysis/index.html
