All enhancements are logged through the bug tracking system. The check is working as designed in regards to validating the entire topology. We liked your idea, but are not sure if it is possible. We will look into it for a future release.
Thank you for the suggestion, Following enhancement has been logged for this request:Bug ID : 8308Title : "Validate Topology" option should honor the Topology rules selection in the check
Have you tried the Polygon Overlap\Gap is Sliver check?This check will look for both overlaps and gaps with a single polygon layer or between two. It has optional parameters to find only those overlaps and gaps that are long and thin or only those smaller than a specified size. However if you leave the Thinness Ratio set to 1 and the Maximum Polygon Area set to 0 Meters, the check will find any overlaps and gaps regardless of size.
