<?xml version="1.0" ?> <configuration label="WCH Search 2"> <layers> <layer> <autoopendatagrid>true</autoopendatagrid> <definitionexpression></definitionexpression> <enableexport>true</enableexport> <name>Buildings</name> <url>http://gis01.wch-rcc.com/ArcGIS/rest/services/Base/Buildings3/MapServer/0</url> <expression>UPPER(name) LIKE UPPER('%[value]%')</expression> <graphicalsearchlabel>Use one of the graphical search tools to select Zoning</graphicalsearchlabel> <spatialsearchlayer>true</spatialsearchlayer> <titlefield>name</titlefield> <fields all="false"> <field name="name" alias="Name" gridfield="true" /> <field name="LONGNAME" alias="LONGNAME" gridfield="true" /> <field name="TYPE" alias="TYPE" gridfield="true" /> <field name="FAC_STATUS" alias="Status" gridfield="true" /> <field name="FAC_CONTRACTOR" alias="Contractor" gridfield="true" /> <field name="rec" alias="rec" gridfield="true" /> </fields> <links/> <zoomscale usegeometry="true" zoompercent="1"></zoomscale> </layer> </layers> <zoomscale>10000</zoomscale> <symbols> <simplefillsymbol color="0xFF0000" alpha="1.0"> <outline color="0x0404B4" alpha="0.8" width="2" /> </simplefillsymbol> <picturemarkersymbol url="assets/images/arrow_up.png" height="20" width="20" xoffset="1" yoffset="1" /> <simplelinesymbol color="0xFA0A56" alpha="0.8" width="2" /> </symbols> </configuration>
<?xml version="1.0" ?> <configuration> <zoomscale>50000</zoomscale> <layers> <layer> <name>APN Search</name> <url>http://permitstweb/ArcGIS/rest/services/Assessor/Prop8Test.4/MapServer/0 </url> <expression>APN = '[value]'</expression> <textsearchlabel>123-456-789-000 (Enter with Dashes) </textsearchlabel> <titlefield>APN</titlefield> <fields> <field name="APN" alias="APN" /> <field name="STREETNUM" alias="" /> <field name="STREETNAME" alias="" /> <field name="STREETTYPE" alias="" /> <field name="ASMT_DESC" alias="Parcel Info" /> <field name="PercentDro" alias="Percent Change" /> <field name="GroupCo" alias="Appraisal Zone" /> <field name="AreaDesc" alias="General Description" /> <field name="AppraisalC" alias="AppraisalCode" /> </fields> </layer> <symbols> <simplefillsymbol color="0xff0000" alpha="0.0"> <outline color="0x00FFFF" alpha="0.8" width="2" /> </simplefillsymbol> <!-- You can have one or the other, either simplemarkersymbol or picturemarkersymbol defined for your point results NOT BOTH. picturemarkersymbol will override simplemarkersymbol if you do not have it commented out. --> <!-- <simplemarkersymbol style="square" size="12" color="0xff0000" alpha="0.5" xoffset="0" yoffset="0" angle="0"> <outline style="solid" color="0x000000" alpha="1" width="1"/> </simplemarkersymbol> --> <picturemarkersymbol url="assets/images/i_search.png" height="20" width="20" xoffset="1" yoffset="1" /> <simplelinesymbol color="0x00FFFF" alpha="0.8" width="2" /> </symbols>
