hi Michael,can you post also the system specs like OS, amount of RAM, graphics card model ?first thing I'd try is update the graphics driver.let me know ..kind greetings !
Hi Helen,Can you try the following :- Delete the folder C:\Users\<name>\AppData\LocalLow\Sun- Then try starting againLet me know..
HelloCollada .dae files that contain a light point seem to cause CityEngine to exit without warning.This happens whether I'm using the insert command or just clicking on the file in the Navigator window.I'm using CE 2011.2 - is there a list of bug fixes somewhere?
Dear Helen,Cityengine comes with its own version of Java. Try adding java.exe from Cityengine/jre/bin to that whitelist.Then, depending on what mechanism your department uses, you might have to add all the dlls in the Cityengine/plugins/<xyz> directories as well. Your administrator should know more about that though.Cheers
Hi Helen,Here's the answer from the developer :Let me know if this helps.
Hi,can you send me the most recent hs_err log file ?(check the creation date)let me know ..m.
Have we confirmed this is a problem or bug with 64-bit?
i am also facing the same problem.
i tried with all the solutions given here.
i am using 2017 version
