Check out this thread for details on how to retrieve all the attributes from the graphic:http://forums.arcgis.com/threads/26234-Identify-Results-2.2-getContent?highlight=getContent
When I click on a row in my datagrid it zooms the map and the infowindow box pops up, but the attributes don't display.How do I get the results to display in the infowindow?ThanksJimmy BrinkThis part of my application based off of the Find Results in DataGrid sample.Code from the onRowClickHandler below:function onRowClickHandler(evt) { // points don't have a getExtent() method... // if selectedWarrant is a point, center the map on it var clickedWarrantID = grid.getItem(evt.rowIndex).OBJECTID; var selectedWarrant; var level = 11; dojo.forEach(map.graphics.graphics, function (graphic) { if ((graphic.attributes) && graphic.attributes.OBJECTID === clickedWarrantID) { selectedWarrant = graphic; map.infoWindow.setContent(graphic.getContent()); return; } }); if (selectedWarrant.geometry.declaredClass == 'esri.geometry.Point') { map.centerAndZoom(selectedWarrant.geometry, map.setLevel(level)); var sp = map.toScreen(selectedWarrant.geometry); //map.infoWindow.setContent(graphic.getContent()); map.infoWindow.show(selectedWarrant.geometry, map.getInfoWindowAnchor(sp)); } else { var WarrantExtent = selectedWarrant.geometry.getExtent(); var screenpoint = map.toScreen(selectedWarrant.geometry.getExtent().getCenter()); var mappoint = map.toMap(screenpoint); map.centerAt(mappoint); map.centerAndZoom(sp, level); map.infoWindow.show(WarrantExtent.getCenter(), map.getInfoWindowAnchor(screenpoint)); } }
