Hi,I am creating a 'Graph' of an attribute of a polyline by taking each point on the line and offsetting it by the (scaled) value.This all works fine except where there are bends (not curves) in the line. At these points I get bowties in the polygon.I tried a convex hull on the polygon but that removed all the concave parts. I also tried unioning the polygon with itself but that didn't work either.I have enclosed a picture of the problem because they may be called something other than bowties elsewhere.Does anyone have an idea for what else I could try?ThanksNavJThe Code is: Public Sub createGraph(ByRef pInLine As IGeometry, ByVal dOffset As Double, ByRef pOutPoly As IGeometry, ByRef sError As String)
' Create a graph polygon as an offset of the polyline pInLine
Dim pBridge As IGeometryBridge2
Dim pSC As ISegmentCollection
Dim pNewGC As IGeometryCollection
Dim pEnumSegs As IEnumSegment
Dim pS As ISegment
Dim pPoly As IPolygon = New Polygon
Dim iPart As Integer
Dim iSeg As Integer
Dim pN As ILine
Dim dX() As Double
Dim dY() As Double
Dim X As Double
Dim Y As Double
Dim i As Integer
Dim j As Integer
Dim iSegTot As Integer
Dim pWKS() As WKSPoint
Dim dDist As Double
Dim pCol As New StringCollection
Dim a() As String
Dim s As String
Try
sError = ""
pOutPoly = New Polygon
pOutPoly.SpatialReference = pInLine.SpatialReference
pPoly.SpatialReference = pInLine.SpatialReference
If pInLine.IsEmpty Then Exit Sub
pBridge = New ESRI.ArcGIS.Geometry.GeometryEnvironment
' Get the offset distance
dDist = dOffset
' Set the input segment collection
pSC = pInLine
iSegTot = 1 + 2 * pSC.SegmentCount
i = iSegTot + 1
ReDim dX(i)
ReDim dY(i)
pNewGC = pOutPoly
' Enumerate over the input segments adding points at i and at iSegTot - i
pEnumSegs = pSC.EnumSegments
pEnumSegs.Next(pS, iPart, iSeg)
i = 0
While IsNothing(pS) = False
X = pS.FromPoint.X
Y = pS.FromPoint.Y
dX(iSegTot - i) = X
dY(iSegTot - i) = Y
' Get the offset point
pN = New Line
pS.QueryNormal(esriSegmentExtension.esriNoExtension, 0, False, dDist, pN)
X = pN.ToPoint.X
Y = pN.ToPoint.Y
dX(i) = X
dY(i) = Y
i = i + 1
End While
' Add the last point
dX(UBound(dX)) = dX(0)
dY(UBound(dY)) = dY(0)
' Remove nulls
For i = 0 To UBound(dX)
If IsNothing(dX(i)) = False AndAlso IsNumeric(dX(i)) AndAlso dX(i) <> 0 Then
If IsNothing(dY(i)) = False AndAlso IsNumeric(dY(i)) AndAlso dY(i) <> 0 Then
pCol.Add(dX(i).ToString & "," & dY(i).ToString)
End If
End If
Next i
ReDim dX(pCol.Count - 1)
ReDim dY(pCol.Count - 1)
For i = 0 To pCol.Count - 1
s = pCol.Item(i)
a = Split(s, ",")
dX(i) = CType(a(0), Double)
dY(i) = CType(a(1), Double)
Next i
' Assemble the points into a polygon
ReDim pWKS(UBound(dX))
j = 0
pWKS(i).X = dX(i)
pWKS(i).Y = dY(i)
Next i
pBridge.AddWKSPoints(pOutPoly, pWKS)
'' Simplify the polygon and union it with itself to get rid of any slivers and bowties
'Dim topologicalOperator2 As ITopologicalOperator2 = CType(pOutPoly, ITopologicalOperator2)
''Simplify.
'topologicalOperator2.IsKnownSimple_2 = False
'topologicalOperator2.Simplify()
'Dim pGeometry As IGeometry = topologicalOperator2.Union(pOutPoly)
'pOutPoly = CType(pGeometry, IPolygon)
Catch ex As Exception
sError = "ERROR: createGraph; Line: " & Erl() & vbCrLf & ex.Message
End Try
End Sub
