The tag 'MeasureAction' does not exist in XML namespace http://schemas.esri.com/arcgis/client/2009'.I'm using Visual Studio 2010..any one get this working?
Found out that the attribute TargetName I specified in <MeasureAction> was not correct!
Yes, I already tried xmlns:esri="http://schemas.esri.com/arcgis/client/2009" first, it didn't resolve the problem. I have to use x:uid. I think it should not affect the esri map. It is more a common thing in wpf anyway.I had looked at the sample before I did all of this. Actually, I'm learning what arcgis offers.
Are you using v2.0 or higher? If so, you can reference esri assemblies this way: xmlns:esri="http://schemas.esri.com/arcgis/client/2009" Have you looked at the SDK sample for MeasureAction? http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#UtilityActionsI'm not sure why you use x:Uid instead of x:Name but the error message does not seem related to that. Maybe try updating your xaml namespace definition (as above) first.
