I created a web app using the web app builder and have several icons for bookmarks which users can click on and zoom to an area. Underneath the icons are the names of the areas which sometimes go onto 2 lines. Prior to the updates, both lines showed but since the updates the second line of the text under the icons is missing. If I go in to edit the bookmarks I can see both lines. Could you tell me if there is anything I can do about this, there is no option to make the text smaller. I have attached an image of the bookmarks, so for instance Greater - should be Greater Manchester or Greater Lincolnshire, Peterborough should be Peterborough and Cambridgeshire.
