I'll try this out and let you know how it went.
Nevermind Eric found it!!Thnx for your help, you were very helpful
Thnx Eric.Now that everything is working fine. I wanted to mash my basemap with those from esri.I read that i must edit the mapmanager.mxml file.But I can't find this file.I already downloaded flashbuilder so i'm just basically can't the mapmanager.mxml file.Do you know maybe where this is located.
Hi Eric,For the first time I was able to see my own basemap in FLEX, following your suggested steps. 🙂 (progress, getting there)But not as type "tiled" but as "dynamic" though.Is there something maybe that I've missed out on. Because the performance of my own current basemap is slow.When I pan to a new area it takes a while to display.Another question, do I need to specify a new cache directory everytime i make a new basemap?David
David,One other thing....here is my procedure for creating a map service that contains aerial imagery:1) I add the imagery into an mxd2) Save it as an msd3) Publish this msd as a service in ArcGIS Server (Map Service)4) Cache the service
David,It appears that you published the wrong type of map service...you need a rest endpoint like this:http://gis-srv3.village.gurnee.il.us/ArcGIS/rest/services/Aerial_1939/MapServerWith MapServer at the end.Hope this helps.Eric
Hi Eric,Thanks for your reply, i appreciate it.I meant raster dataset. I 've made a service of it then "cached" it using the example of the link I've posted earlier.But when I type: myserver/arcgis/rest/services I see the following:[ATTACH=CONFIG]12955[/ATTACH]The type layer stays raster 😞 I've tried changing the type in the config.xml file to tiled, but it gives me an error: Satelite layer failed to load: Fault code: nullFault info: E0005E: Invalid tile service: http://myserver/ArcGIS/rest/services/DEMOS/Setar_Sat_2011/ImageServerFault details: nullSo my question is what am i doing wrong?Thank UDavid
Hi there,I've been trying to use my own basemap in flexviewer.I've a raster layer but after I've done some researched I found out that a raster layer could not be used as a basemap.Only dymanic, wms, tiled, image and arcIMS layers are supported to use as basemap.Then I've tried this link: http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//00530000000v000000But as a service it still shows the data type as raster layer.My question is: what can I do with my data (which is raster) to yet use it as a basemap.thank you
