var idParams = new IdentifyParameters(); idParams.width = map.width; idParams.height = map.height; idParams.geometry = evt.mapPoint; idParams.mapExtent = map.extent; idParams.layerOption = IdentifyParameters.LAYER_OPTION_VISIBLE; idParams.layerIds = layer.visibleLayers; idParams.tolerance = 3; idParams.returnGeometry = true; idParams.spatialReference = map.spatialReference;
Note: In the case of dynamic layers the layer list is ignored, it instead uses top or all (default) to identify the layers defined in dynamicLayers parameter.
Have you tried setting the layerIds property of the IdentifyParameters? var idParams = new IdentifyParameters(); idParams.width = map.width; idParams.height = map.height; idParams.geometry = evt.mapPoint; idParams.mapExtent = map.extent; idParams.layerOption = IdentifyParameters.LAYER_OPTION_VISIBLE; idParams.layerIds = layer.visibleLayers; idParams.tolerance = 3; idParams.returnGeometry = true; idParams.spatialReference = map.spatialReference;
