Rotate Selected graphic with mouse move angle ?
I have added graphics in graphicslayer. what i want is on mouse click event get selected graphics and when mouse move change the angle of the selected graphic with mouse move event.here it is updating the graphic angle and position with mouse move but it is updating the whole graphics layer not the selected one. how to rotate and update only selected graphic position and angle? any idea ? here my code is below..
using System;
using System.Collections.Generic;
using System.Linq;
using System.Net;
using System.Windows;
using System.Windows.Controls;
using System.Windows.Documents;
using System.Windows.Input;
using System.Windows.Media;
using System.Windows.Media.Animation;
using System.Windows.Shapes;
using ESRI.ArcGIS.Client;
using ESRI.ArcGIS.Client.Geometry;
using ESRI.ArcGIS.Client.Symbols;
using System.Collections.Specialized;
namespace RotateGraphicText
public partial class MainPage : UserControl
private DragGraphic _dragGraphic = null;
private Random _random = new Random();
ESRI.ArcGIS.Samples.RotatingTextSymbol rt = new ESRI.ArcGIS.Samples.RotatingTextSymbol();
double angle;
public MainPage()
InitializeComponent();
// Get layers
ArcGISTiledMapServiceLayer topoLayer = this.Map.Layers[0]
as ArcGISTiledMapServiceLayer;
GraphicsLayer graphicsLayer = this.Map.Layers[1]
as GraphicsLayer;
// Wait until the map service layer has loaded and initialized
topoLayer.Initialized += (a, b) =>
rt.Text = "MyTest";
for (int i = 0; i < 10; i++)
graphicsLayer.Graphics.Add(
new Graphic()
// Create a random location
Geometry = new MapPoint()
X = topoLayer.InitialExtent.XMin +
this._random.NextDouble() *
(topoLayer.InitialExtent.XMax -
topoLayer.InitialExtent.XMin),
Y = topoLayer.InitialExtent.YMin +
(topoLayer.InitialExtent.YMax -
topoLayer.InitialExtent.YMin)
// Use the markersymbol defined in the resource
Symbol = rt
graphicsLayer.Graphics.CollectionChanged += (a, b) =>
// Exit if not added graphic
if (b.Action != NotifyCollectionChangedAction.Add) { return; }
// Get added graphic
Graphic graphic = b.NewItems[0] as Graphic;
// When the graphic is clicked, store the current state
graphic.MouseLeftButtonDown += (sender, e) =>
this._dragGraphic = new DragGraphic()
Graphic = graphic,
GraphicOrigin = graphic.Geometry as MapPoint,
MouseOrigin = this.Map.ScreenToMap(e.GetPosition(null))
e.Handled = true;
// Delete selected graphic
//graphicsLayer.Graphics.Remove(b.NewItems[0] as Graphic);
//angle = Angle(this._dragGraphic.GraphicOrigin.X, this._dragGraphic.GraphicOrigin.Y, this._dragGraphic.MouseOrigin.X, this._dragGraphic.MouseOrigin.Y);
// When the mouse is moved update the graphic's position
graphic.MouseMove += (sender, e) =>
if (this._dragGraphic == null) { return; }
this._dragGraphic.Graphic.Geometry = new MapPoint()
X = this._dragGraphic.GraphicOrigin.X +
(this.Map.ScreenToMap(e.GetPosition(null)).X -
this._dragGraphic.MouseOrigin.X),
Y = this._dragGraphic.GraphicOrigin.Y +
(this.Map.ScreenToMap(e.GetPosition(null)).Y -
//X = this._dragGraphic.GraphicOrigin.X, Y = this._dragGraphic.GraphicOrigin.Y
angle = Angle(this._dragGraphic.GraphicOrigin.X, this._dragGraphic.GraphicOrigin.Y, this._dragGraphic.GraphicOrigin.X +
this._dragGraphic.MouseOrigin.X), this._dragGraphic.GraphicOrigin.Y +
this._dragGraphic.MouseOrigin.Y));
rt.Angle = angle;
// Clear the seleced graphic on mouse up
graphic.MouseLeftButtonUp += (sender, e) =>
this._dragGraphic = null;
// Adjust the selected graphics position if the mouse moves
this.Map.MouseMove += (sender, e) =>
//double angle = Angle(this._dragGraphic.MouseOrigin.X, this._dragGraphic.MouseOrigin.Y, this._dragGraphic.MouseOrigin.X + 2, this._dragGraphic.MouseOrigin.Y + 2);
//Y = this._dragGraphic.GraphicOrigin.Y
rt.Angle = angle;
public double Angle(double px1, double py1, double px2, double py2)
// Negate X and Y values
double pxRes = px2 - px1;
double pyRes = py2 - py1;
double angle = 0.0;
// Calculate the angle
if (pxRes == 0.0)
if (pxRes == 0.0)
angle = 0.0;
else if (pyRes > 0.0) angle = System.Math.PI / 2.0;
else
angle = System.Math.PI * 3.0 / 2.0;
else if (pyRes == 0.0)
if (pxRes > 0.0)
angle = 0.0;
else
angle = System.Math.PI;
else
if (pxRes < 0.0)
angle = System.Math.Atan(pyRes / pxRes) + System.Math.PI;
else if (pyRes < 0.0) angle = System.Math.Atan(pyRes / pxRes) + (2 * System.Math.PI);
else
angle = System.Math.Atan(pyRes / pxRes);
// Convert to degrees
angle = angle * 180 / System.Math.PI; return angle;
public class DragGraphic
public Graphic Graphic { get; set; }
public MapPoint MouseOrigin { get; set; }
public MapPoint GraphicOrigin { get; set; }
