var attInspector = new AttributeInspector({ layerInfos:layerInfos }, "attributesDiv"); attInspector.on("attribute-change", function(evt) { var feature = evt.feature; //keep all fields the same from the input feature.attributes[evt.fieldName] = evt.fieldValue; //override the USER_ field with the userId from the credentials object feature.attributes.USER_ = esri.id.credentials[0].userId; //apply attribute update feature.getLayer().applyEdits(null, [feature], null); //refresh to show the 'behind the scenes' edit attInspector.refresh(); });
I am adding a updated version of the code using AMD for anyone that is interested using. The one I provided was Legacy Dojo using dojo.connects.
I just wrote this five minutes ago. With this one you don't have to worry were the listener goes inside the function. This is a working exmaple.
The way it works once you click on the map to add a point then before apply edits executes and in there you tell javascript to edit a particular field automatic. It auto populates that field. Look for the listener that say before-apply-edits and I apply it to a particular attribute.
My Contact information:
email: hchapa@lrgvdc911.org
phone: 956-682-3481 ext. 143
<!DOCTYPE html>
<html>
<head>
<title>Edit rivers and waterbodies</title>
<link rel="stylesheet" href="https://js.arcgis.com/3.16/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="https://js.arcgis.com/3.16/esri/css/esri.css">
<style>
html,body{height:100%;width:100%;margin:0;overflow:hidden;}
#map{
padding:0;
#header{
font-size: 1.1em;
font-family: sans-serif;
padding-left: 1em;
padding-top:4px;
color:#660000;
.templatePicker {
border: none;
.dj_ie .infowindow .window .top .right .user .content { position: relative; }
.dj_ie .simpleInfoWindow .content { position: relative; }
</style>
<script src="https://js.arcgis.com/3.16/"></script>
<script>
var map;
require([
"esri/map",
"esri/tasks/GeometryService",
"esri/layers/ArcGISTiledMapServiceLayer",
"esri/layers/FeatureLayer",
"esri/Color",
"esri/symbols/SimpleMarkerSymbol",
"esri/symbols/SimpleLineSymbol",
"esri/dijit/editing/Editor",
"esri/dijit/editing/TemplatePicker",
"esri/config",
"dojo/i18n!esri/nls/jsapi",
"dojo/_base/array", "dojo/parser", "dojo/keys",
"dijit/layout/BorderContainer", "dijit/layout/ContentPane",
"dojo/domReady!"
], function(
Map, GeometryService,
ArcGISTiledMapServiceLayer, FeatureLayer,
Color, SimpleMarkerSymbol, SimpleLineSymbol,
Editor, TemplatePicker,
esriConfig, jsapiBundle,
arrayUtils, parser, keys
parser.parse();
// snapping is enabled for this sample - change the tooltip to reflect this
jsapiBundle.toolbars.draw.start = jsapiBundle.toolbars.draw.start + "<br>Press <b>ALT</b> to enable snapping";
// refer to "Using the Proxy Page" for more information: https://developers.arcgis.com/javascript/3/jshelp/ags_proxy.html
esriConfig.defaults.io.proxyUrl = "/proxy/";
//This service is for development and testing purposes only. We recommend that you create your own geometry service for use within your applications.
esriConfig.defaults.geometryService = new GeometryService("https://utility.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
map = new Map("map", {
basemap: "satellite",
center: [-96.541, 38.351],
zoom: 14,
slider: false
map.on("layers-add-result", initEditor);
//add boundaries and place names
var labels = new ArcGISTiledMapServiceLayer("https://server.arcgisonline.com/ArcGIS/rest/services/Reference/World_Boundaries_and_Places/MapServer");
map.addLayer(labels);
var responsePoints = new FeatureLayer("https://sampleserver6.arcgisonline.com/arcgis/rest/services/Wildfire/FeatureServer/0", {
mode: FeatureLayer.MODE_ONDEMAND,
outFields: ['*']
var responsePolys = new FeatureLayer("https://sampleserver6.arcgisonline.com/arcgis/rest/services/Wildfire/FeatureServer/2", {
map.addLayers([responsePolys, responsePoints]);
responsePoints.on("before-apply-edits", function(evt){
console.log(evt);
if(evt.adds[0])
//Here you choose which attribute to update...
evt.adds[0].attributes.description = "Testing this one out works fine";
function initEditor(evt) {
var templateLayers = arrayUtils.map(evt.layers, function(result){
return result.layer;
var templatePicker = new TemplatePicker({
featureLayers: templateLayers,
grouping: true,
rows: "auto",
columns: 3
}, "templateDiv");
templatePicker.startup();
var layers = arrayUtils.map(evt.layers, function(result) {
return { featureLayer: result.layer };
var settings = {
map: map,
templatePicker: templatePicker,
layerInfos: layers,
toolbarVisible: true,
createOptions: {
polylineDrawTools:[ Editor.CREATE_TOOL_FREEHAND_POLYLINE ],
polygonDrawTools: [ Editor.CREATE_TOOL_FREEHAND_POLYGON,
Editor.CREATE_TOOL_CIRCLE,
Editor.CREATE_TOOL_TRIANGLE,
Editor.CREATE_TOOL_RECTANGLE
toolbarOptions: {
reshapeVisible: true
var params = { settings: settings };
var myEditor = new Editor(params, 'editorDiv');
//define snapping options
var symbol = new SimpleMarkerSymbol(
SimpleMarkerSymbol.STYLE_CROSS,
15,
new SimpleLineSymbol(
SimpleLineSymbol.STYLE_SOLID,
new Color([255, 0, 0, 0.5]),
5
null
map.enableSnapping({
snapPointSymbol: symbol,
tolerance: 20,
snapKey: keys.ALT
myEditor.startup();
</script>
</head>
<body class="claro">
<div id="main" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline'" style="height:width:100%;height:100%;">
<div data-dojo-type="dijit/layout/ContentPane" id="header" data-dojo-props="region:'top'">
Edit Hydrography
</div>
<div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'left'" style="width: 300px;overflow:hidden;">
<div id="templateDiv"></div>
<div id="editorDiv"></div>
<div data-dojo-type="dijit/layout/ContentPane" id="map" data-dojo-props="region:'center'"></div>
</body>
</html>
Can someone clarify inside of the sample provided where Hector's code goes? This would be hugely helpful!
Thanks!
Yes, it's the code to auto-populate a field.
No, I don’t unfortunately.
Do you have teamviewer?
Hey Matthew what code do you need.
I have to code to autoPopulate a field.
Hi, Hector. I would love to see that code! I am struggling w/ the same problem as above.
require([ "esri/map", "esri/tasks/GeometryService", "esri/toolbars/edit", "esri/graphic", "esri/Color", "esri/dijit/HomeButton", "esri/dijit/BasemapGallery", "esri/dijit/LocateButton", "esri/dijit/Geocoder", "esri/layers/ArcGISDynamicMapServiceLayer", "esri/layers/FeatureLayer", "esri/symbols/SimpleMarkerSymbol", "esri/symbols/SimpleLineSymbol", "esri/dijit/editing/Editor", "esri/dijit/editing/TemplatePicker", "esri/config", "dojo/i18n!esri/nls/jsapi", "dojo/on", "dojo/_base/array", "dojo/parser", "dojo/keys", "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!" ], function( Map, GeometryService, Edit, Graphic, Color, HomeButton, BasemapGallery, LocateButton, Geocoder, ArcGISDynamicMapServiceLayer, FeatureLayer, SimpleMarkerSymbol, SimpleLineSymbol, Editor, TemplatePicker, esriConfig, jsapiBundle, on, arrayUtils, parser, keys ) { parser.parse(); //This service is for development and testing purposes only. We recommend that you create your own geometry service for use within your applications. esriConfig.defaults.geometryService = new GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer"); map = new Map("map", { basemap: "streets", center: [-98.185272, 26.282376], logo: false, sliderStyle: 'large', zoom: 9, }); var home = new HomeButton({ map: map }, "HomeButton"); home.startup(); geoLocate = new LocateButton({ map: map }, "LocateButton"); geoLocate.startup(); var geocoder = new Geocoder({ arcgisGeocoder: false, autoComplete: true, zoomScale:1000, geocoders: [ { url: "http://maps.lrgvdc911.org:6080/arcgis/rest/services/Public_Outreach/SDE_ADDRESS_POINTS_130917_Create2/GeocodeServer", name: "LRGVDC ", placeholder: "Locate", outFields: "*", singleLineFieldName: "SingleLine" }], map: map }, "search"); geocoder.on('select', function (candidate) { for(var i = 0; i< 20; i++) { var geom = candidate.result.feature.geometry; var symbol = new SimpleMarkerSymbol(); symbol.setStyle(SimpleMarkerSymbol.STYLE_CIRCLE); symbol.setColor(new Color([155, 0, 61, 0.75])); var graphic = new Graphic(geom, symbol); map.graphics.clear(); map.graphics.add(graphic); } }) geocoder.on('clear', function(){ map.graphics.clear(); }) var basemapGallery = new BasemapGallery({ showArcGISBasemaps: true, map: map }, "basemapGallery"); basemapGallery.startup(); basemapGallery.on("error", function(msg) { console.log("basemap gallery error: ", msg); }); map.on("layers-add-result", initEditor); //add boundaries and place names var dynamic = new ArcGISDynamicMapServiceLayer("http://maps.lrgvdc911.org:6080/arcgis/rest/services/STEAR/STEAR_DYNAMIC/MapServer"); map.addLayer(dynamic); var events = new FeatureLayer("http://maps.lrgvdc911.org:6080/arcgis/rest/services/Public_Outreach/EVENTS/FeatureServer/0",{ mode: FeatureLayer.MODE_ONDEMAND, outFields: ['EVENT_NAME', 'date','address', 'psap'] }); map.addLayers([events]); function initEditor(evt) { var templateLayers = arrayUtils.map(evt.layers, function(result){ return result.layer; }); var templatePicker = new TemplatePicker({ featureLayers: templateLayers, grouping: true, rows: "auto", columns: 1 }, "draggable"); templatePicker.startup(); var layers = arrayUtils.map(evt.layers, function(result) { return { featureLayer: result.layer }; }); var settings = { map: map, templatePicker: templatePicker, layerInfos: layers, toolbarVisible: true, createOptions: { polylineDrawTools:[ Editor.CREATE_TOOL_FREEHAND_POLYLINE ], polygonDrawTools: [ Editor.CREATE_TOOL_FREEHAND_POLYGON, Editor.CREATE_TOOL_CIRCLE, Editor.CREATE_TOOL_TRIANGLE, Editor.CREATE_TOOL_RECTANGLE ] }, toolbarOptions: { reshapeVisible: true } }; var params = {settings: settings}; var myEditor = new Editor(params,'editorDiv'); //define snapping options var symbol = new SimpleMarkerSymbol( SimpleMarkerSymbol.STYLE_CROSS, 15, new SimpleLineSymbol( SimpleLineSymbol.STYLE_SOLID, new Color([255, 0, 0, 0.5]), 5 ), null ); map.enableSnapping({ snapPointSymbol: symbol, tolerance: 20, snapKey: keys.ALT }); myEditor.startup(); } });
on(editLayer, 'update', function (evt) { populateNumber(); }); }); function populateNumber(){ var input = document.getElementById('dijit_form_TextBox_0'); if(input.value.length == 0) input.value = "Empty";
