I have a feature class that has several sql db tables joined to it. It's been my workflow to update values in these tables, and then export the joined feature class over to sde GDB to use for published map services. I'm trying to automate this step using python. Is there a way in Python to open a map document (with the feature class and joined tables), select the feature class and export the feature class to a Geodatabase? Any help would be much appreciated.
Thank you
