As I understand it, Arc 10 will no longer support the use of Crystal reports. I am trying to find out if the arc reports has anything like the flexibility of Crystal. It seems that none of the developers care if we can report.
Hi,I recently migrated my ArcObjects .NET code from ArcGIS 9.3 to ArcGIS 10. I have a tool which open/creates a report in Crystal Report 12 within ArcMap. In ArcGIS 10 however the Crystal Report refuses to open or get created. Instead it throws an exception when Loading Report which says that Failed due to error "8007007f". I looked online for 8007007f error and found that it was due to incorrect installation of OLEDB32.dll. So I got the correct version but did work either.I finally found that the assembly CrystalDecisions.ReportAppServer.ClientDoc.dll is not loading inside ArcMAP. If I try the same outside arcMap as a windows application it works. However does not work as part of ArcObjects ICommand.Any help is appreciated.Thank you,sirisha.
