Chris,The output of Snap Pour Point is a raster. You input your point features, specify a radius, and it will move the 'feature' to the highest value cell of the flow accumulation grid within the radius. It's similar to what your doing but easier. It also virtually guarantee's you won't hit that occasional issue you mention. Watersheds that are single pixels or just a few is basically 99.9% an extent setting issue. If someone is using pour points, the way to verify the extent is the problem is to take the resulting (wrong) watershed raster and display the nodata pixels as some color. You'll find the extent of the watershed raster is limited by the geographic extent of the pour points and is not equal in extent to the DEM, flow direction, or flow accumulation rasters. This issue can be avoided by running the Snap Pour Point tool and specifying output extent = Flow Dir, Accumulation, or DEM. Snap Raster should always be set.Regards,Eric
