I am creating a label expression in Pro using Arcade. Are there any tags or functions in arcade to make part of the label text bold?
Looking for something similar to the <BOL>[Field1]</BOL> tags that are available in VBscript.
Thank you
You can use something similar in Arcade:
<SPAN class="string token">"<BOL>"</SPAN> <SPAN class="operator token">+</SPAN> $feature<SPAN class="punctuation token">.</SPAN>Field1 <SPAN class="operator token">+</SPAN> <SPAN class="string token">"</BOL>"</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>
Xander,
Do you know if using these codes will be possible in AGOL in the future? I am currently using an arcade expression in a webmap popup configuration to return a number of fields from a related table based on this post, and I would like to be able to format (bold, in this case) the values from one of the returned fields. Since there are multiple fields being returned, I am not aware of a way to style it using custom HTML in a way that would only apply to one of the fields.
Lindsay
In ArcGIS Online you cannot use these codes. You can style the pop-up using custom HTML instead of normal fields display.
Is this possible in ArcGIS Online as well? I just tried it and it doesn't seem like it works, but perhaps I'm missing something.
