HiI try to export map with annotation with PrintingTools and I found export map with one annotation layer only takes about 1-2 minutes to A4 landscape pdf 1:2000 600 dpi. While export map with one polygon layer takes about 5-6 seconds and 5-6 different polygon and polyline layers 6-7 seconds also.Is there a way to increase the speed of export map with the annotations layer?BTW. Dynamic service vs feature layer from dynamic service.Map export to A4 pdf 1:2000 with operational layer from my dynamic service Hydrography with one layer Sea takes 76 seconds. Map export to A4 pdf 1:2000 from Feature layer Sea (map service) from this dynamic service Hydrography takes 5-6 seconds. Hardware: HP ML350 G4p 2*Xeon 3.00 GHz 8 RAM SCSI RAID 5Software Windows 2008 R2 Standard, ArcGIS for Server WG 10.1 sp1, Viewers for Flex 3.6 or for Silverlight 3.2.Help me pleaseThanks.Oleg
To many variables to be able to narrow it down.1. it could be that your machine is not powerful enough to handle a large number of calculations.2. Polygon layers take more resources to export. Annotation is treated as a polygon. If your annotation is feature linked that takes longer as well3. if your data is on a network that can make it take longer.4. pause the drawing while exporting. This will free up resources for your computer.5. if your working in a geodatabase or SDE you should compress it6 run disk defrag and disk cleanup on your computer7 how much free space does your hard drive have? If it is under 15% you should free as much up as possible. and run defrag and disk clean up again.8. for your export settings. Lower it down to 300 or better yet 150. 600 is good but that is a huge drag on the export. Change the output image quality down to normal. on the Advanced tab when exporting set it to Layers and Attributes to NONE and do not export georeference info
