Hi, I am using a hosted feature Layer, how can I get representations to work in my web map?
Hannes
HI,
The only option I know so far, is to create .tpk file in ArcMap and publish it as hosted tile layer on ArcGIS.com. If you need attributes as well, share your data as hosted feature service and set transparency accordingly
Regards,
Adam
Hmm, that seems like it would be too static. I wanted the symbology to update whenever a change is made to the data. The only other way I can think of is to create two separate feature classes and link them with a relationship class with shared messages, but I wanted to avoid doing that because I also don't know if it is possible in ArcGIS Online. More research!
Other way is to use ArcGIS for Server Map Service with Feature Access Enabled. Add MapService and FeatureService (transparent). Edit Feature service, Map Service is for display only. There is no better way to do so, according to my knowledge. If you find something betterm please share it.
