Chris,You're running into two different things here.1. Joins and relates are not supported when packaging the data with your published map.Troubleshooting data packaging limitationsPackaging layers with ArcMap joins and relates topic.2. The attachment issue is a bug.NIM061515: When opening a packaged PMF in ArcReader, feature attachments are not viewable in the Identify window if the 'File Geodatabase', 'Compress File Geodatabase', and 'Compressed and Locked File Geodatabase' data formats were selected during the data packaging process.The workaround for this bug is to select the "Copy data in existing format" on the General tab when packaging the data from the Publisher toolbar.- - - - - - - -My suggestion to you, in this situation, might be to use relative paths to your data and then send them the pmf along with data all in one folder. The map will open, data sources intact, when opened on another computer.Preparing maps for publishingYou store relative paths in the MXD, File > Map doc properties > Store relative pathnames to data sources.Store all of your data in one windows folder, stick the pmf (unpackaged) in there, zip folder, and send.
