Hi,I am trying to add a kml layer to my map. However, the control reaches onError handler and shows 'File not found. Wrong Url' error. The Url is correct and I can get back data if I use it on a IE browser.Why should the code fail with this error? Any input is appreciated.Our server isn't accessible from outside. If I see in developer tools where the url is appended to http://utility.arcgis.com/sharing/kml?url=myurl ==> this returns File not found error and I am sure Kml layer isn't getting loaded because of this. But, how should I fix this?Thanks!
How do I render KML files that are hosted on intranet sites on a map?The KmlLayer class that generates KML overlays in the Google Maps API uses a Google hosted service to retrieve and parse KML files for rendering. Consequently it is not possible to display KML files that are not hosted at a URL that is available publicly accessible, or that require authentication to access.If you need to develop applications that use KML files hosted on intranet sites we recommend that you either:Use the Google Earth API which supports client side parsing and rendering of KML.Render the KML on the client side by using third-party JavaScript libraries. As the KML file is analyzed by the browser, performance may be lower than by using the KmlLayer class.
