The DWG in question is only 693 kb. For reference I have other much larger DWG files that load fine. I have since learned it is not just my computer it will not load on others as well, pretty sure it is the DWG file itself. The surveyor has resent it several times in different versions. So at a loss right now. The DWG loads fine in AutoCAD and has the appropriate local coordinate system.Thanks.
How big is the file and does it contain a lot of text? I know when I used to bring CAD files into ArcMap, the amount of text in the CAD file dramatically affected the load time (which may seem like ArcMap is hung). By removing the text, I was able to greatly decrease the time ArcMap took to process the CAD file. A few pieces of text should not cause any problems but having hundreds of text elements in the CAD did. It was a very exponential curve.Also I notice that sometimes CAD files will have huge extents since there may be a couple elements far away (often near the origin) from the main body of the drawing. ArcMap seems to slow down when the spatial extents are that big.
