Hi,Sorry for the inconvenience, the source of your issue may be: * ArcGIS Online having temporary trouble creating Feature Service. Did you give it a second chance another day? * The FS creation really failed. You may see it in ArcGIS Online but it may be invalid * The FS creation succeeded but Map Tour didn't received the response in time, so it consider it as failedWhat you can do is to add your FS to the Map Tour webmap yourself through ArcGIS.com map viewer (use Add->Search for layers, it is important that you use that way and not Add->Add Layer from Web). Then try to use Map Tour builder and see how it goes.
Hi,Thanks for the response. I had been trying to create the feature service over a few days. I created the feature service in Map Tour with errors, the only option I have there is to create it in Root, then went to my Map Viewer to Add-Search for Layers. The layer is listed but cannot be added and has the status Unavailable. When I try to Create Service from My Content, I get the error:Service 'https://services1.arcgis.com/HCIJ2DmtdLnNlsE1/arcgis/rest/services/NameofMyFS/FeatureServer' does not exist or is inaccessible.Thanks
