Do you have any samples that will run a buffer based on query parcel result(s)?
Thank you.
Take a look at this update JSFiddle:
Edit fiddle - JSFiddle
Thank you for the sample. I try to understand it so I modify it to create a Buffer button instead of automatically generate buffer ring on query.
Here is the JSFiddle:
How to perform this task?
Thanks again.
The link was missing a colon. Here it is: Edit fiddle - JSFiddle
I was going to have to ask a question similar to this eventually too.
Hi Jeff,
Here is an example you can build off of. The app uses the Find Task to search and find a parcel based on the Parcel ID. It then automatically buffers the selected polygon by 500 feet.
Similar to generate address mailing list. For example, search parcel then do a buffer button based on certain distance and generate a lists from buffer results.
Do you have example can do this?
