Public Sub Test() ' This code expects the first layer in the TOC to be a raster ' Get map Dim pMXD As IMxDocument Set pMXD = ThisDocument Dim pMap As IMap Set pMap = pMXD.FocusMap ' Get raster Dim pLayer As ILayer Set pLayer = pMap.Layer(0) Dim pRasterLayer As IRasterLayer Set pRasterLayer = pLayer ' Get extent Dim pGeoDataset As IGeoDataset Set pGeoDataset = pRasterLayer Dim pEnv As IEnvelope Set pEnv = pGeoDataset.Extent ' Test minimum value, assumes rasters are not in decimal degrees If pEnv.XMin = -0.5 Then Debug.Print "This raster has no extent so can't be geo-referenced!" Else Debug.Print "This raster is geo-referenced!" End If End Sub
