<esri:GeometryService id="geometryService" concurrency="last" fault="onFaultGeo(event)" projectComplete="projectCompleteHandler(event)" url="http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer"/>
private function bufferGPS():void { var bufferParameters:BufferParameters = new BufferParameters(); bufferParameters.geometries = [ map point to buffer ]; bufferParameters.distances = [this will be where you put the accuracy number]; // Note: As of version 2.0, the buffer constants have been moved to GeometryService. bufferParameters.unit = GeometryService.UNIT_METER; bufferParameters.bufferSpatialReference = map.spatialReference; bufferParameters.outSpatialReference = map.spatialReference; geometryService1.addEventListener(GeometryServiceEvent.BUFFER_COMPLETE, bufferCompleteHandler); geometryService1.buffer(bufferParameters); function bufferCompleteHandler(event:GeometryServiceEvent):void { geometryService1.removeEventListener(GeometryServiceEvent.BUFFER_COMPLETE, bufferCompleteHandler); // Note: As of version 2.0, GeometryService returns geometries (instead of graphics) for each (var geometry:Polygon in event.result) { var graphic:Graphic = new Graphic(); graphic.geometry = geometry; graphic.symbol = fillSymbol; myGraphicsLayer.add(graphic); } }
private function locate():void { if (Geolocation.isSupported==true) { //Initialize the location sensor. geolocation = new Geolocation(); geolocation.setRequestedUpdateInterval(5000); geolocation.addEventListener(GeolocationEvent.UPDATE, onTravel); } else { Alert.show("Geolocation feature not supported"); } } //geolocation event listener private function onTravel(event:GeolocationEvent):void { var long:String = event.longitude.toString(); var lat:String = event.latitude.toString(); var longnew:Number = Number(long); var latnew:Number = Number(lat); var GPSPoint:MapPoint = new MapPoint(longnew, latnew); GPSPoint.spatialReference = new SpatialReference(4326); var outSR:SpatialReference = new SpatialReference(2234); geometryService.project([GPSPoint as Geometry], outSR); }
hey, thanks for the replies, yes i've written a trace() into the following if statement: protected function myMap_loadHandler(event:MapEvent):void { if (Geolocation.isSupported) {trace("geo loop begin"); geo = new Geolocation; if (!geo.muted) // check if Geolocation is not disabled on the device {trace("geo on"); zoomToCurrentLocationImg.source = m_gpsA; zoomToCurrentLocationImg.visible = true; } } }i get the "geo loop begin" trace but not the "geo on", i've checked the device settings and geolocation works fine in all other apps.any ideas?! do others have this working?thanksBen
