I get this error when attempting to use the FeatureLayer selectFeatures method using a dynamically generated polygon geometry:In "?v=2.8 [dynamic]":Microsoft JScript runtime error: 'xmin' is null or not an object (Ln 48, Col 41494, Ch 41494)Ultimately, I want to use the actual geometry in a KML Layer to query another FeatureLayer, rather than use the Extent object of the KML geometries. I'm trying to create a new geometry object that contains all of the KML Layer geometries. There may be a better way to do this...When evaluating breakpoints I can tell that the code fails on this line: targetLayer.selectFeatures(query);Looking closer, I can see that the extent property is null for the new Geometry object after this line: geom.addRing(graphic.geometry);The graphic.geometry has a valid extent property (and presumably a valid geometry), but the geom object has an invalid extent after this line. Any thoughts or suggestions for me?Thanks for your help!AndrewI'm using JavaScript API v2.8Where kmlLayer = an esri KMLLayer object that contains a polygon for the state of Wyoming (http://dl.dropbox.com/u/2654618/kml/Wyoming.kml) and targetLayer = an esri FeatureLayer object:function selectByLoadedLayer() { if (kmlLayer) { var geom; var layers = kmlLayer.getLayers(); dojo.forEach(layers, function (lyr) { if (lyr.graphics && lyr.graphics.length > 0) { if (lyr.declaredClass == "esri.layers.FeatureLayer") { if (lyr.geometryType == "esriGeometryPoint") { geom = new esri.geometry.Multipoint(map.spatialReference); dojo.forEach(lyr.graphics, function (graphic) { geom.addPoint(graphic.geometry); }); } else if (lyr.geometryType == "esriGeometryPolygon") { geom = new esri.geometry.Polygon(map.spatialReference); dojo.forEach(lyr.graphics, function (graphic) { geom.addRing(graphic.geometry); }); } else if (lyr.geometryType == "esriGeometryPolyline") { geom = new esri.geometry.PolyLine(map.spatialReference); dojo.forEach(lyr.graphics, function (graphic) { geom.addPath(graphic.geometry); }); } } else { alert("KML layer contains a non-FeatureLayer layer object"); } } }); } else { alert("Please load an uploaded file or a network link first."); } //initialize & execute query var query = new esri.tasks.Query(); query.geometry = geom; query.returnGeometry = true; targetLayer.selectFeatures(query); }
