//create find task with url to map service findTask = new esri.tasks.FindTask("http://ingisd01/ArcGIS/rest/services/Tokanui/tokanui_paddock_test/FeatureServer"); //create find parameters and define known values findParams = new esri.tasks.FindParameters(); findParams.returnGeometry = true; findParams.layerIds = [0]; findParams.searchFields = ["PadID","Caption"];} //end of init funcfunction execute(searchText) { //set the search text to find parameters findParams.searchText = searchText; findTask.execute(findParams, showResults);}function showResults(results) { //symbology for graphics var markerSymbol = new esri.symbol.SimpleMarkerSymbol(esri.symbol.SimpleMarkerSymbol.STYLE_SQUARE, 10, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255, 0, 0]), 1), new dojo.Color([0, 255, 0, 0.25])); var lineSymbol = new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_DASH, new dojo.Color([255, 0, 0]), 1); var polygonSymbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_NONE, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_DASHDOT, new dojo.Color([255, 0, 0]), 2), new dojo.Color([255, 255, 0, 0.25])); //find results return an array of findResult. map.graphics.clear(); var dataForGrid = []; //Build an array of attribute information and add each found graphic to the map dojo.forEach(results, function (result) { var graphic = result.feature; dataForGrid.push([result.layerName, result.foundFieldName, result.value]); switch (graphic.geometry.type) { case "point": graphic.setSymbol(markerSymbol); break; case "polyline": graphic.setSymbol(lineSymbol); break; case "polygon": graphic.setSymbol(polygonSymbol); break; } map.graphics.add(graphic); }); var data = { items: dataForGrid }; var store = new dojo.data.ItemFileReadStore({ data: data }); grid.setStore(store);}function initEditor(results) { //build the layer and field information for the layer, display the description field using a text area. var layers = dojo.map(results, function (result) { var fieldInfos = dojo.map(result.layer.fields, function (field) { if (field.name === 'Caption') { return { 'fieldName': 'Caption', 'label': 'Caption', stringFieldOption: esri.dijit.AttributeInspector.STRING_FIELD_OPTION_TEXTAREA }; } else { return { 'fieldName': field.name, 'label': field.alias }; } }); return { featureLayer: result.layer, 'fieldInfos': fieldInfos }; }); var settings = { map: map, enableUndoRedo: true, layerInfos: layers, toolbarVisible: true, createOptions: { polygonDrawTools: [ esri.dijit.editing.Editor.CREATE_TOOL_FREEHAND_POLYGON, esri.dijit.editing.Editor.CREATE_TOOL_AUTOCOMPLETE ] }, toolbarOptions: { reshapeVisible: true, cutVisible: true, mergeVisible: true } }; var params = { settings: settings }; editorWidget = new esri.dijit.editing.Editor(params, 'editorDiv'); //create a new checkbox to enable/disable snapping var checkBox = new dijit.form.CheckBox({ name: "chkSnapping", checked: true, id: "chkSnapping", label: "Snapping", showLabel: "false", title: "Snapping", onChange: function (evt) { console.log(this.checked); if (this.checked) { map.enableSnapping({ snapKey: dojo.keys.copyKey }); } else { map.disableSnapping(); } } }); //add the snapping checkbox to the editor's toolbar var myToolbarElement = dojo.query(".esriDrawingToolbar", editorWidget.domNode)[0]; var myToolbar = dijit.byId(myToolbarElement.id); myToolbar.addChild(new dijit.ToolbarSeparator()); myToolbar.addChild(checkBox); editorWidget.startup(); //listen for the template pickers onSelectionChange and disable //the snapping checkbox when a template is selected var templatePickerElement = dojo.query(".esriTemplatePicker", editorWidget.domNode)[0]; var templatePicker = dijit.byId(templatePickerElement.id); dojo.connect(templatePicker, "onSelectionChange", function () { if (templatePicker.getSelected()) { //disable the snapping checkbox dijit.byId('chkSnapping').set("disabled", true); } else { dijit.byId('chkSnapping').set("disabled", false); } }); map.infoWindow.resize(325, 200);}
