C# Flash Code http://help.arcgis.com/en/sdk/10.0/arcobjects_net/componenthelp/index.html#//004900000075000000 ComboBox ListBox Where Clause example calling Flash Geometry private void btnZoom_Click(object sender, EventArgs e) { try { string strWhere; Boolean boStatus = ckbQuery.Checked; IMxDocument IMxDoc = (IMxDocument)ArcMap.Application.Document; ILayer iLayer1; //HARD CODED //Build where Clause if (rdName.Checked) { strWhere = "Allot_NAME = '" + listName.SelectedItem.ToString() + "' AND " + "ADM_OFC_CD = '" + cmbOffice.Text + "'"; } else { strWhere = "ST_ALLOT = 'ID" + listNumber.SelectedItem.ToString() + "'"; } //Hard Coded if (iLayer != null) { iLayer1 = cUtils.ExistsFeatureReturnLayer((IMap)IMxDoc.FocusMap, iLayer); if (iLayer1 != null) { cUtils.SelectFeatureQuery(iLayer1, strWhere, boStatus); } else { cUtils.AddLayerToActiveView(IMxDoc.ActiveView, iLayer); IMxDoc.ActiveView.Refresh(); cUtils.SelectFeatureQuery(iLayer, strWhere, boStatus); } } } catch { } } public void SelectFeatureQuery(ILayer iLayer, string sQuery, Boolean bDef) { IFeatureLayer iFeatureLayer = iLayer as IFeatureLayer; IFeatureLayerDefinition iFLD = iFeatureLayer as IFeatureLayerDefinition; IFeatureSelection iFeatureSelection = iFeatureLayer as IFeatureSelection; IQueryFilter iQF = new QueryFilter(); ISelectionSet iSelSet; try { UID uUID = new UID(); uUID.Value = "esriArcMapUI.ClearSelectionCommand"; ArcMap.Application.Document.CommandBars.Find(uUID).Execute(); if (bDef) { iFLD.DefinitionExpression = sQuery; } else { iFLD.DefinitionExpression = ""; } iQF.WhereClause = sQuery; iFeatureSelection.SelectFeatures(iQF, esriSelectionResultEnum.esriSelectionResultNew, false); iFeatureSelection.SelectionChanged(); iSelSet = iFeatureSelection.SelectionSet; if (iFeatureSelection.SelectionSet.Count == 0) { MessageBox.Show("Feature Not Found!", "Query Results"); } else { uUID.Value = "esriArcMapUI.ZoomToSelectedCommand"; ArcMap.Application.Document.CommandBars.Find(uUID).Execute(); //example passing flash parameters delete Application.DoEvents(); FeatureClassUtils fc = new FeatureClassUtils(); IFeature feature = iFeatureLayer.FeatureClass.GetFeature(iSelSet.IDs.Next()); IGeometry ig = feature.Shape; IRgbColor iColor = new RgbColor(); iColor.RGB = 233; IMxDocument iMxDoc = ArcMap.Document; fc.FlashGeometry(ig, iColor, iMxDoc.ActiveView.ScreenDisplay, 1000); } } catch { } }
Please see the work flow in the sample available at http://support.esri.com/en/knowledgebase/techarticles/detail/20500
