Which is why our lab uses postgis/postgresql for our database. We got tired of dealing with esri's database efforts.The File Geodatabase is a delicate creature.
We currently use ZigGIS.We were hoping for native support without the use of ArcSDE and native ArcCatalog read/write management support.I suppose it is a little too much to ask for.We use PgAdmin to manage. ZigGIS for the Read/Write of postgis features in ArcGIS.Actually we find we use ArcGIS less for Analysis work, and more for the pretty map making tools.
I am having a similar problem. We are running SDE 9.3 and I am working on upgrading an extension that I wrote before I upgrade all the existing 9.3 users to ARC 10. Using ARC 10 on my desktop whenever I try to edit data stored on SDE I get an error stating that the Jet Database cannot find the table "GDB_DataChanges". The code fails on the ifeature.Store method. I am assuming that this is a compatibility problem with a ARC 10 Desktop trying to edit a 9.3 database. But I am here hoping to find a way around this problem. ARC10 should be backward compatible.
