Brian,
Did you try the detach-attach route? I've got to move several workgroup geodatabases to enterprise soon. I tried that approach going from personal sde to workgroup. It was easy and worked beautifully. I'm working with 10.2, so I may be up against other issues, because Esri has changed how you authorize enterprise databases.
Jill
Jill,
Yes I ended up following the steps listed above and it worked fine to go from workgroup to enterprise. That was for 10.1, and I think 10.2 would be the same. I don't recall having to authorize it, but perhaps I did. That is done through a GP tool now and not the command line. Good luck!
Brian
Thanks, Brian. I wound up using restore from backup and it worked like a
charm. No authorizing needed. One advantage to restoring rather than
detach-attach is that it leaves the original GDB operational until I can
get MXDs repointed the new location.
Jill Halchin
Archeologist / GIS Coordinator
Southeast Archeological Center
National Park Service
Tallahassee FL 32310
850-580-8429
jill_halchin@nps.gov
Webpage: http://www.nps.gov/seac/
Facebook: https://www.facebook.com/NPSSEAC
Twitter: https://twitter.com/NPSSEAC
