Domains in FGDB not being showing in AGOL was reported as a bug.
Any news on this?
When a File Geodatabase is shared to ArcGIS Online via .zip file: Domains also remain in the geodatabase, but are not accessible from the hosted feature layer. Documentation for this is here.
If you want access to the domains in the hosted feature service you will have to share your feature class(es) by using File > Share As > Service from ArcMap. Steps are here.
Domains created in ArcGIS for Desktop usually do not have issues persisting when shared as a feature service to ArcGIS Online (at least in my experiences). However, I have read some bugs with domains when your data uses subtypes.
Do you have the bug # that you are referring to? Which method are you using to share your FGDB to ArcGIS Online?
No subtypes. Created the FGDB, feature class, imported table as domain, assigned domain to feature class through Arc Catalog 10.2.2. The domain description shows up in the preview and Arc Map. I zip up the geodatabase. In AGOL I import the zipfile as a fgdb.
Ok, I see. But what about the table related to the feature class? The related table also has domains.
