I am a little bit confused about the steps to install and configure Java SDK with InteliJIDEA IDE and not with Eclipse.
Can you guys help me with that?
Ionut
If you're happy to use Gradle...
It's pretty simple. Create New Project > Gradle Project ...
Then edit your build.gradle and place sources as per example below:
Develop your first map app with Gradle—ArcGIS Runtime SDK for Java | ArcGIS for Developers
Add a "run configuration" via the Gradle Docker. Select your project and add a task "run"
Should be really simple. Took me 5 minutes.
Gradle / IntelliJ Project here: Gradle - Help | IntelliJ IDEA
It worked! Thanks a lot.
I didn`t had to download the SDK, the build.gradle took care of it
Thanks,Ionut
Hi Mark,
I`ll test it out and let you know !
Thanks a lot!
Regards,
